Date/Time: Mon, 10 Mar 2025 10:52:40 +0000
See the same open orders on Multiple Computers using Teton Order Routing
View Count: 533
[2022-03-24 16:59:13] |
eminimom - Posts: 24 |
--I have converted from Transact to Teton Routing Order & new a broker. My question relates to settings so that I will have a true simultaneous view of open orders/charts/DOM whether in SIM or LIVE on both computers. --I have a SECOND computer set up as a backup/MRROR to run the same MAIN startup + 3 instances that are shown on the REGULAR trading computer. --The SECOND computer will be used as a MIRROR to close out trades if there is a failure on the MAIN computer. I use Chart Trade Mode On and a Trade DOM for each MAIN and instance, one per market. --I have paid for a second exchange fee on the second computer. --Since each instance is effectively a new load of Sierra Charts to distribute the RAM load, how can I see the same trades on both machines simultaneously? -------1. Current settings: SIM mode...I currently have the MAIN & SECOND computers and each of the 3 instances set to TRADE SIMULATION MODE ON. Do I toggle OFF the TRADE SIMULATION MODE ON for Instances #2,3,4 on both computers so all DOM & orders will be accessed from the MAIN startup workspace on each computer? -------2. For LIVE trading, what settings should the MAIN and each of the instances for all the LIVE trades to be shown? |
[2022-03-26 10:35:10] |
Sierra_Chart Engineering - Posts: 18725 |
-------1. Current settings: SIM mode...I currently have the MAIN & SECOND computers and each of the 3 instances set to TRADE SIMULATION MODE ON. Do I toggle OFF the TRADE SIMULATION MODE ON for Instances #2,3,4 on both computers so all DOM & orders will be accessed from the MAIN startup workspace on each computer? What you want to do is not supported in this way.There is no way to share internal simulated trading activity outside of an instance or its sub instances. The solution is you need to use the Simulated Futures Trading service: Simulated Futures Trading Service -------2. For LIVE trading, what settings should the MAIN and each of the instances for all the LIVE trades to be shown? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-26 10:35:42
