Date/Time: Tue, 26 Nov 2024 06:37:46 +0000
Request: Profile Coloring Option For Numbers Bars
View Count: 1257
[2014-04-21 19:39:55]
cmet - Posts: 551
Can you please consider a coloring option for numbers bars that is based on Volume Profile?
This would include the VPOC outline as you have it now as well as the ability to highlight the value area.
Why this would be helpful: It would allow you to see where Value was on each bar to better time entry on pullbacks and set stops. It would also help you to easily see where value is a bar by bar basis.
For example, an 8 tick Range Bar in the ES would look something like this quick mockup I did:
http://s27.postimg.org/vh8d73hxv/profile_Coloring.jpg
Date Time Of Last Edit: 2014-04-21 20:09:41
