Date/Time: Mon, 10 Mar 2025 10:29:43 +0000
cross hair y axis label
View Count: 505
[2022-03-24 15:00:17] |
lservin29 - Posts: 65 |
I use the cross hair with the horizontal line visible but the vertical line hidden. I would like to add a price label on the y axis that show the price point of where I currently have the horizontal line. Can this be done
[2022-03-24 16:52:57] |
John - SC Support - Posts: 38516 |
Make sure that the setting for Global Settings >> Tool Settings >> Chart Values >> Show Y Value and Time Boxes is set to Yes. Refer to the following: Chart Drawing Tools: Show Y Value and Time Boxes (Tool Settings >> Chart Values >> Chart Values For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-24 17:08:08] |
on that same note can you isolate to have the Y-axis value show but NOT the date and time that is displayed on the X-axis on the footer?
[2022-03-24 17:39:37] |
No, there is not an option for this. It is either both or none.
