Date/Time: Mon, 10 Mar 2025 10:51:58 +0000
ZIGZAG INDICATOR SHOWING ZEROS ...NO VOLUME
View Count: 480
[2022-03-24 14:52:49] |
User410836 - Posts: 18 |
Hi, I subscribed for your services...package 5, but my zigzag indicator showing just zeros....no volume or ticks...thanks |
[2022-03-24 16:40:11] |
John - SC Support - Posts: 38516 |
Our guess is that you are trying to accumulate a Volume other than Total Volume ("Volume to Accumulate" Input). Since you are using CQG data, any historical data will not have the Bid and Ask information to properly accumulate anything other than Total Volume. Refer to the 2nd bullet point here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 If you feel this is not the issue, then we need to see a screenshot and what your "Volume to Accumulate" is set to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
