Date/Time: Mon, 10 Mar 2025 10:30:57 +0000
Alerts
View Count: 447
[2022-03-24 14:36:10] |
User485486 - Posts: 43 |
Hi, I wanted to know if the only way to alert is by writing a formula or if there is another simpler way (for example, a built-in price / indicator crossing alert) Thanks |
[2022-03-24 16:10:24] |
John - SC Support - Posts: 38516 |
There are a couple of other alert types - Symbol Alert and Drawing Alert that use a simpler interface. Refer to the information here: Alerts Manager: Symbol Alerts and here: Chart Drawing Tools: Chart Drawing Alerts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
