Date/Time: Mon, 10 Mar 2025 10:52:05 +0000
Spreadsheet system formula for exit positions l-3 & N-3 HELP!
View Count: 636
[2022-03-24 13:14:07] |
User9890731 - Posts: 47 |
What formula must I add to l-3(sell exit) and n-3(buy exit) in order to have the spreadsheet close a trade when a signal no longer appears on k-3 or m-3 on the current bar. Basically if the signal appears on the column then an entry is made, but when the same signal on the same column disappears then the spreadsheet should flatten the position until a new signal is generated. I already have an entry formula for k-3 and m-3; =ID1.SG1@3 > 0 =ID1.SG2@3 > 0 |
[2022-03-24 13:31:22] |
Sawtooth - Posts: 4181 |
Try this: L3: =AND(K4>0,K3=0) N3: =AND(M4>0,M3=0) |
[2022-03-24 15:31:31] |
Hi Tomgilb, Thanks for the reply, but it still failed to flatten the position, or is there an option in the spreadsheet study settings that I should set to ''yes'' for it to work. I have attached the test. |
[2022-03-24 15:41:59] |
OK, try this: L3: =ID1.SG1@3 = 0 N3: =ID1.SG2@3 = 0 |
[2022-03-24 15:57:44] |
Awesome! Works perfectly, thanks!
