Date/Time: Mon, 10 Mar 2025 10:52:41 +0000
Empty chart
View Count: 614
[2022-03-24 12:59:46]
User837393 - Posts: 143
This morning I decided to pull out an old chart (footprint) that I've made during the March contract.
When I loaded the chartbook it asked me to roll over, which I did, but now the chart is just emtpy.
Right clicking on the chart is not possible also... nothing happends.
The other charts in the chartbook works fine, but not sure what is going on with this one.
Anyways to debug that ?
Best regards.
Date Time Of Last Edit: 2022-03-24 13:23:45
Private File
[2022-03-24 16:00:23]
John - SC Support - Posts: 38516
The Footprint chart shows up fine for us (Chart #2). Here is an image of the chart:
https://www.sierrachart.com/image.php?Image=1648137555872.png
If you are having an issue with this chart, then right click on the price ladder on the right and select 'Reset'. IF that does not fix your issue, then let us know and give us a screen image of what you are seeing.
[2022-03-24 16:13:01]
This is what I see.
https://www.sierrachart.com/image.php?Image=1648138329815.png
[2022-03-24 17:32:40]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-03-24 18:06:41]
Edit...
Was sent privately for analysis
Date Time Of Last Edit: 2022-03-24 18:09:44
[2022-03-24 18:25:22]
The one thing we can see is that you are using the March ES contract which is no longer trading. You need to change to the June contract. Make this change and then see if you continue to have an issue.
