Date/Time: Tue, 26 Nov 2024 06:30:36 +0000
MA
View Count: 1014
[2014-04-21 17:53:25] |
User31465 - Posts: 5 |
I have a MA I used in Ensing Windows I am trying to re-create in SC. It is a double EMA 9/34 with only the 34 showing, when the 9 is above the 34 the 34 is green and when it is below the 34 the 34 is red. thanks for the great support! Scott |
[2014-04-21 18:22:03] |
This can be done by using the Color Bar Based on Alert Condition study. Using that study it is possible to color the Moving Average in this way. https://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s252 And the Moving Average-Exponential study with a length of 9 can be hidden by enabling Hide Study in the Study Settings window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
