Date/Time: Fri, 25 Sep 2026 05:38:35 +0000
Possible for a vertical line to appear across multiple instruments at the same timestamp?
View Count: 706
[2022-03-24 02:12:04]
HumblyTrading - Posts: 222
Hello SC Team,
Is it possible to copy an object, such as a vertical line, across several instruments, so that the user can compare price action at that point in time?
This would make it possible to mark up several trade moments, for example, and compare whether the trade was better on ES, NQ, etc.
Thanks for any help!
Mike
[2022-03-24 14:51:05]
John - SC Support - Posts: 48003
You can always create a drawing and then copy that to other charts. refer to the following:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
But there is also the ability to see the crosshairs on multiple charts at the same point in time which may be the easier solution for what you are wanting. Refer to the following:
Chart Drawing Tools: Global Cursor (Tools >> Global Cursor On)
