Date/Time: Fri, 07 Feb 2025 15:15:39 +0000
Price Volume Bars
View Count: 1045
[2022-03-23 19:20:21] |
User737477 - Posts: 19 |
Hi guys, I'm using a renko chart but is there a way to show variable volume [as in the variable colour / width] of the renko bar itself? Thanks https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62742 |
[2022-03-23 22:31:02] |
John - SC Support - Posts: 37809 |
There is not support for Price Volume Renko Bars, but there are regular Price Volume Bars. Refer to the information here: Graph Draw Types: Candle Price Volume Bars If you want to color the bars based on a volume amount, then you could use multiple copies of the Color Bar Based on Alert Condition study to do this. Refer to the information here: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
