Date/Time: Mon, 10 Mar 2025 10:36:33 +0000
How do I extend a chart further to the left?
View Count: 697
[2022-03-23 19:10:40]
CJBuckets - Posts: 20
Downloaded a chartbook and there are point/volume values at the bottom and top of each renko bar range. I cant see the new values that are being made because I can only drag the chart a little to the right. For example, every time a new candlestick is made the chart extends one candlestick size to the right and that's it. How do I get it to where I can drag the chart as far right as I want with the hand tool?
[2022-03-23 22:19:43]
John - SC Support - Posts: 38516
It sounds like you have the option for Lock Fill Space enabled. This will limit how far to the left you can move the chart as it will lock the last bar at that position. The easy solution is to disable Lock Fill Space. Refer to the information here:
Chart Settings: Lock Fill Space (Chart >> Chart Settings >> Display >> Chart Display Items menu)
