Date/Time: Mon, 10 Mar 2025 10:34:51 +0000
DOM not showing market depth data at each price
View Count: 554
[2022-03-23 17:50:51]
User850090 - Posts: 26
Hello. Any clue why my DOM is not showing market data at each price and skips always one level. IT DOES THE SAME FOR BID/ASK Current, Recent, Stacking/Pulling data. See picture. Thanks
imageDOM Price 1.png / V - Attached On 2022-03-23 17:50:09 UTC - Size: 67.99 KB - 144 views
[2022-03-23 18:57:36]
What is the Tick Size of the chart set to?:
Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
In this case it should be set to .25.
The other thing to check is this setting:
Chart Settings: Market Depth Combine Increment in Ticks (Chart >> Chart Settings >> Market Depth menu)
Date Time Of Last Edit: 2022-03-23 18:58:21
[2022-03-24 11:35:47]
Hello. I have tick set up to .25. NQ futures are missing more data at each price. See pickure. Thanks
imageMissing data ticks 1.png / V - Attached On 2022-03-24 11:35:17 UTC - Size: 125.52 KB - 140 views
[2022-03-24 12:18:20]
For that chart, make sure this is set to 0:
If you still have an issue follow the instructions here to disable the use of Custom Symbol Settings Values:
Global Symbol Settings: Disabling Custom Symbol Settings
