Date/Time: Mon, 10 Mar 2025 10:35:12 +0000
Financial Exchange traded spreads
View Count: 507
[2022-03-23 15:13:49] |
User737477 - Posts: 19 |
Hi guys, I'm connected using Teton, but I'm struggling to find the exchange traded spreads anywhere - when I switch to "SC Data All Services", I can locate the spreads easily but when using Teton link, these spreads disappear from the lists when one clicks "Get Spreads". The documentation states that exchange traded spreads should be visible using the Teton option - any ideas how I can remedy this please? FYI, I'm just looking for things like NOB / BOB / FUT spreads with DOM depth. If I switch over to the "SC Data All services", am I able to trade with this feed? I've attached a picture showing you the available spreads using the Teton link, as you can see, the usual spreads are missing. Thanks, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=62729 |
[2022-03-24 00:17:39] |
This is pending review. Thank you.
[2022-03-24 16:13:34] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings You will now see NOB / BOB / FUT spreads listed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
