Date/Time: Mon, 10 Mar 2025 06:54:32 +0000
How to get real-time data feed for US equities
View Count: 635
[2022-03-22 16:24:11] |
itsminhly - Posts: 2 |
Hey I've purchased a few things under recommendation from other posts, but I still haven't figured out how to receive live-data for US stocks. It shows delayed data regardless of the package I have. I'm not sure what else I'm supposed to do. The only thing I haven't gotten was the NASDAQ US package for 16/month. Can I get a direct purchase for ONLY US stocks. I liked Sierra Charts mainly for the variety of studies and only want to incorporate that into trading stocks Thanks |
[2022-03-22 17:38:06] |
Also after playing around the only thing that shows live data feed is the NASDAQ NQTV. Though you can't trade, I just purchased the US package cause why not, but I have no clue what any of it does because there's no description
[2022-03-22 18:14:49] |
Yes you will receive real-time data, for any stock with the -NQTV suffix. Example: AAPL-NQTV. You do have the NASDAQ exchange active. If you are using Interactive Brokers and you want to trade from a chart using set to a -NQTV symbol, then what you need to do is set Chart >> Chart Settings >> Trade and Current Quote Symbol to the Interactive Brokers symbol using the symbol format documented here: Interactive Brokers Symbols: Stock Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
