Date/Time: Tue, 26 Nov 2024 08:47:26 +0000
GENERAL SUPPORT FOR NEW USER
View Count: 800
[2022-03-22 15:11:28]
User519646 - Posts: 15
I would like to have support general charting support and add chart setups. I will pay the cost . Also like to have data from you if that possible. Thanks
[2022-03-23 20:24:19]
John - SC Support - Posts: 36286
We refer people to Diana Pena as someone that can help you with this. You can contact her here:
https://bio.link/dianapena
[2023-08-30 02:54:45]
I sent you message log. There are errors coming every other second.
[2023-08-30 14:16:30]
We see the following in the log:
TC Client socket (4) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
This means that you are having a network connection issue of some kind. Refer to the information at the following link:
Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem
