Date/Time: Mon, 10 Mar 2025 07:01:11 +0000
Data Issue not posting correctly
View Count: 417
[2022-03-21 19:32:51] |
User203192 - Posts: 33 |
I have built a spreadsheet for trading and trying to dump value data for alerts to the spreadsheet. I have price overlay attached to the chart to the spreadsheet to correlate the data to the spreadsheet column which is working fine. Alerts trigger and value is present in Column but the data left in relation to the alert is not of time of entry. It is simply the bar it triggered from and it post the value of the end of the bar time frame and not the time of entry to the alert. I need to know how to get the value to be left at the time/date the alert triggers and not the bar it triggers on in relation to all the exact value labels of time of entry and not the bar it triggers?
[2022-03-22 00:27:07] |
Sawtooth - Posts: 4181 |
With a spreadsheet study, it is not possible to make an intrabar value persistent. With a spreadsheet study, only values at the Close of bar can be make persistent. |
[2022-03-22 00:53:11] |
This is complex, what you are doing and the requirements. This is not within the scope of our support. However, when you cannot do something with Spreadsheets we recommend using ACSIL instead: Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL)) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
