Date/Time: Mon, 10 Mar 2025 07:12:04 +0000
changing brokers
View Count: 725
[2022-03-21 18:12:25] |
User73630 - Posts: 19 |
I have been using Sierra Charts for many years. I was using Tradovate with CQG data. I realized I need to change, so I've decided to use Ironbeam for my new broker. I assume you consider them a good choice for partnering with SC since it's one you recommended. I have opened an account and funding will clear on 3-24-22. I want to use Teton order routing with Denali data feed. My question is do I need to go ahead and Initiate that now within my SC account so it will be ready and if so how do I do that seeing that I currently am using CQG (do I disconnect with CQG first) or do I need to wait until Ironbeam tells me to do so on there end? Thanks for your help. Ray
[2022-03-21 19:17:28] |
Yes you do need to wait: or do I need to wait until Ironbeam tells me to do so on there end?
When they are ready you just simply follow the instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
