Date/Time: Mon, 10 Mar 2025 07:16:59 +0000
Keyboard shortcuts can conflict with symbol field in Chart Settings window
View Count: 563
[2022-03-21 16:51:52] |
sean3000 - Posts: 65 |
When trying to change the chart symbol via the Chart Settings window, keyboard shortcuts take precedence over text entry. For example, if a shortcut key is mapped to "e" then it is impossible to enter a lowercase "e" into the symbol field. Instead, the shortcut action assigned to the "e" key is activated. |
[2022-03-21 23:25:13] |
We should be able to resolve this.
