Date/Time: Mon, 10 Mar 2025 07:09:09 +0000
I switched to sierra chart teton and I have a problem
View Count: 496
[2022-03-21 16:14:57]
User752881 - Posts: 9
HI
I have several computers, and I'm authorized to work with the same SIERRA CHART account
On some computers
"Allowed Systems: 3 out of a total of 4 system (s) are currently being used."
The problem is that since I switched to SIERRA CHART TETON
Only one computer SIERRA CHART works
And on the other computers SIERRA CHART does not respond to the price movement, the price stands still and does not move as if it is not connected to DATA FEED
I've changed the settings, and there's still no change
Regards
[2022-03-22 01:01:37]
Yes this is due to market data controls as required by exchanges. Refer to:
Denali Exchange Data Feed: Connections
If you did not have a problem previously, this means the previous data provider was not compliant with market data rules.
Date Time Of Last Edit: 2022-03-22 01:01:47
