Date/Time: Mon, 10 Mar 2025 06:45:48 +0000
Monitor Display resolution
View Count: 1214
[2022-03-21 15:13:18] |
User223734 - Posts: 103 |
May I know which is best display resolution (i.e. Full HD, 2K or 4K) for Sierra Chart?
[2022-03-21 18:08:45] |
It does not matter. Whatever you require. Refer to: Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
