Date/Time: Mon, 10 Mar 2025 07:17:29 +0000
Partial Fills on Limit Orders
View Count: 509
[2022-03-21 14:29:48] |
User696540 - Posts: 29 |
Hello, If one is entering the market with a Stop Limit order on say 5 contracts, but only 3 are IMMEDIATELY filled....is it possible to AUTOMATICALLY have the 2 unfilled orders cancelled? Or do you need to do that manually? Some markets move so fast that I don't want the unfilled orders to get filled if the price has already made the move that I wanted and then is reversing back the other way. Also, how are attached Stop and Target orders handled in trying to cancel out the unfilled contracts? Thanks much. |
[2022-03-21 18:12:33] |
This is not supported to do this automatically. You just have to cancel that original parent order. And there is nothing special to do with the Attached Orders after that. They will just have a quantity equal to the Fill quantity of the parent order.
