Date/Time: Mon, 10 Mar 2025 16:08:35 +0000
slow update performance with 2368
View Count: 609
[2022-03-21 14:11:03] |
User656492 - Posts: 146 |
Very slow performance with this update. Please address ASAP. |
[2022-03-21 15:42:08] |
sorry, not true. i rolled back to previous version with same chartbooks and all is fine.
[2022-04-03 12:36:15] |
Just stay on the older version. We do not know what the issue is in your case. It is extremely unlikely we would be able to reproduce the problem either. Also refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.44 - Performance Differences Between Versions of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-04-03 12:44:58
