Date/Time: Mon, 10 Mar 2025 06:56:27 +0000
Issue with Order Configuration
View Count: 398
[2022-03-21 13:58:57] |
User148596 - Posts: 217 |
Hi, I'm having an issue whereby I have a -36 offset (ticks) Type: Stop: Stop set and none selected for Move to breakeven for stop. But I'm getting taken out of the trade at -12 ticks. There's nothing in my global profit loss settings that would cause this. When I placed the bracket order the Stop order appeared on the chart in the correct place (-36t) but then executed the order at -12t and I can't figure out why that would happen. Thanks |
[2022-03-21 17:20:22] |
See if the execution was with that Stop order or another new order. Refer to: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
