Date/Time: Mon, 10 Mar 2025 07:14:22 +0000
[User Discussion] - Flex Renko question (confusion)
View Count: 574
[2022-03-21 13:09:22]
User92573 - Posts: 547
Dear Support
I have a quick question surrounding the Flex-renko and I've read all the documentation.
When selecting for example:
Flex Renko: BarSize-TrendOff-RevOff (12-11-1)
Gap Fill: None
Method: New Trend Bar When Range Met | New Reversal Bar When Reversal Amount Met Plus 1 Tick and References Prior Close
I'm a little confused by the settings/explanation.
- Flex-Renko Settings - Taken from manual.
- Flex-Renko 12-11-1 - Settings captured from Platform.
What I'm unsure of is the 'method' setting above and the third value which is 'Reversal offset.'
Surely, they are the same? However, if they are different can you explain in what way and which has preference?
Many thanks.
imageFlex-Renko Settings.png / V - Attached On 2022-03-21 13:04:40 UTC - Size: 293.43 KB - 160 views
imageFlex-Renko 12-11-1.png / V - Attached On 2022-03-21 13:04:51 UTC - Size: 175.72 KB - 154 views
