Date/Time: Mon, 10 Mar 2025 06:51:30 +0000
New Build - Daily Candles - Set to Intraday Only - Not showing the range
View Count: 549
[2022-03-21 10:39:40] |
HeyUgly - Posts: 251 |
good morning, On the newest build, Daily candles im having issues with , never seen this before. I switch a daily candle to "intraday only" , it sets back to a 30min candle. After numerous attempts, i finally get it to go, its not showing the premarket session fully, its missing alot of the range from this am. This is happening on multiple charts, Mainly stocks im noticing it. Any ideas whats going on? is it a bug possibly in the new build? |
[2022-03-21 10:52:52] |
i have been able to somewhat get it to work, Setting daily to "intraday" and not "intraday only" intraday only is producing false candles.
[2022-03-22 12:18:38] |
There is a problem with the Chart Data Type setting in the new Chart Settings window. We are fixing this. It is not saving the setting. But several of the things you are describing, are unrelated to this, and make no technical sense to us. Things like this: " intraday only is producing false candles.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-22 12:21:01
