Date/Time: Mon, 10 Mar 2025 16:05:41 +0000
[User Discussion] - Developing in ACSIL, running a seperate dev machine or seperate instance?
View Count: 527
[2022-03-21 10:28:22] |
YSS - Posts: 112 |
Hello, I have live trading account linked to Sierrachart Teton routing and I want to develop some of my tools and strategies in ACSIL but I want to seperate this so by accident I do nothing on my live trading account, so what do you suggest: 1. Disconnect live trading on my main sierrachart instance while coding in ACSIL and only use the Denali feed 2. Using a second SC instance from my main Sierrachart instance, don't have it connectd to live trading, and code from there 3. Just be safe if I'm worried and just run it on another machine and pay twice for SC Denali while coding. 4. Or is there another safe mechanism so I don't have to worry a thing Thanks |
[2022-04-03 16:40:50] |
ForgivingComputers.com - Posts: 1021 |
Develop in Sim mode either in the same instance you do you live trading in, which keeps things simple, or in another instance. You should be able to use the SC-Data feed on a second machine without paying extra, since it is delayed and you would always keep it in Sim mode.
Date Time Of Last Edit: 2022-04-03 16:42:49
