Date/Time: Mon, 10 Mar 2025 06:55:05 +0000
Reset Study ID Numbers?
View Count: 489
[2022-03-21 02:12:31]
User429065 - Posts: 128
In the "Studies to Graph" how can I reset all the study ID numbers so they are in numerical sequence from top to bottom or bottom to top? After piecing a subset together then eliminating unwanted studies they get chaotic. Just trying to clean it all up. See attached. Thank you!
Date Time Of Last Edit: 2022-03-21 05:39:22
imageStudies not in Order.JPG / V - Attached On 2022-03-21 02:10:14 UTC - Size: 27.25 KB - 131 views
[2022-03-22 01:23:11]
This is not possible to do. You just have to remove the studies and add them again.
Date Time Of Last Edit: 2022-03-22 01:23:30
[2022-03-22 03:28:57]
Sawtooth - Posts: 4181
If there are no chart drawing links and no alert formula references between ID#s, and no Based On references, you can do it with duplicating/removing studies.
This allows you to retain the settings of each.
Date Time Of Last Edit: 2022-03-22 16:39:32
