Date/Time: Tue, 15 Sep 2026 20:02:51 +0000
Vwap doesn't plot after 15:30
View Count: 888
[2022-03-19 22:25:23]
Technical - Posts: 158
I set up a generic chart with a default vwap. The Session time is 00:00:00 to 23:59:59, which I assume is a 24 hour day.
For some reason, vwap doesn't pot from 15:30 until midnight.
I can't figure it out - please see enclosed picture.
[2022-03-20 12:20:14]
Does not really make much sense. What is the exact name of the study, and is this a Sierra Chart built in study or a custom study?
We recommend checking all of the study Inputs and referring to the relevant documentation:
Volume Weighted Average Price (VWAP) - Rolling with Standard Deviation Lines
[2022-03-20 13:55:44]
It is the generic VWAP configured with default settings. It is not rolling, just the vanilla VWAP.
I created a fresh chart, and added one study, Sierra's built-in VWAP.
imageVWAP Plot 2022-03-19 17_11_49-Sierra Chart #2 2364 Vix focus.png / V - Attached On 2022-03-20 13:54:43 UTC - Size: 223.41 KB - 266 views
[2022-03-20 21:06:27]
We are fairly sure the reason for this, is the lower volume in the evening session. So the prices in the evening session have little/non-perceivable impact upon the volume weighted average price from the period before.
Date Time Of Last Edit: 2022-03-20 22:04:02
[2022-03-21 12:54:20]
I checked other platforms to which I have access, and their default VWAP indicator does appear to have sufficient volume to show movement during overnight hours. See enclosed:
imageTrade2022-03-21 07_47_13-ES1! .png / V - Attached On 2022-03-21 12:50:57 UTC - Size: 206.41 KB - 269 views
imageTOS 2022-03-21 07_41_27-Paper@thinkorswim [build 1973].png / V - Attached On 2022-03-21 12:52:04 UTC - Size: 89.36 KB - 270 views
[2022-03-21 13:33:46]
We stand by the calculation and the explanation we gave really would be the explanation for this.
One way to validate this is to look at the mathematical formulas we provide:
Volume Weighted Average Price (VWAP) with Standard Deviation Lines
And then add the Numbers Bars study to the chart, and manually do the calculations:
Numbers Bars
To make this easier you can set the chart bars to something like 360 minutes per bar.
Date Time Of Last Edit: 2022-03-21 13:34:08
