Date/Time: Mon, 10 Mar 2025 06:55:45 +0000
NQTV Symbols
View Count: 846
[2022-03-19 09:44:27]
user8888 - Posts: 159
Another great addition the NASDAQ Total View DF. Thank you!
1 Q: What would be the Symbol for the Google/Alphabet stock?
Cheers
[2022-03-19 11:21:15]
1+1=10 - Posts: 270
GOOG-NQTV (Class C Shares)
GOOGL-NQTV (Class A Shares)
[2022-03-19 12:23:49]
Ok
I still don't see it, but it worked. It is there, somewhere ...
Thank you
imageGOOG.PNG / V - Attached On 2022-03-19 12:23:10 UTC - Size: 34.53 KB - 177 views
[2022-03-19 12:33:00]
1+1=10 - Posts: 270
Oh, yes, SC just hand-picked some stocks to show up in the clickable list. They probably forget to include GOOG/GOOGL. However, you can type in its name or any other stock/ETF not on the list into the symbol text field and the data will load. See picture.
imageScreen Shot 2022-03-19 at 8.29.24 AM.png / V - Attached On 2022-03-19 12:31:50 UTC - Size: 343.47 KB - 176 views
