Date/Time: Wed, 27 Nov 2024 06:46:03 +0000
Study: Write Bar Data to File
View Count: 827
[2022-03-19 05:19:37]
aelagha - Posts: 31
Hi there,
This study is supposed to write (Date-Time, Open, High, Low, Close, Volume) to a file (Write Bar Data to File). However, I am also getting additional fields (# of Trades, OHLC Avg, HLC Avg, HL Avg, Bid Volume, Ask Volume). I tried several things in the Chart Settings, but tehy only affect what gets displayed in the Tool Values Window. Is there a way to disable these additional values to file?
Thx
[2022-03-19 11:28:31]
1+1=10 - Posts: 270
1. When you save the file, change the extension from .txt/.itxt to .csv
2. Open the file in spreadsheet software of your choice.
3. Delete columns you don’t need.
[2022-03-19 18:33:20]
aelagha - Posts: 31
Thanks, but that is not what I was looking to do. Sure you can always post-process the file. It looks like there is a way to prevent saving these additional fields, especially the study help does not list them as being written.
Thanks again.
[2022-03-22 17:17:34]
We will follow up on this as soon as we can.
[2023-09-12 08:14:33]
Flo_O - Posts: 4
Hello Sierra Team,
Is there a solution yet?
I'm exporting large files too for backtest reasons and reducing the unused columns from bar data like OHLC HL avg would help very much.
Or something else like a split file by day feature.
Thank you so much
Florian
Date Time Of Last Edit: 2023-09-12 08:15:51
