Date/Time: Mon, 10 Mar 2025 10:34:34 +0000
Strings assigned to s_SCNewOrder::TextTag do not get saved for 'other' accounts
View Count: 559
[2022-03-18 15:46:40] |
User99735 - Posts: 234 |
Strings assigned to s_SCNewOrder::TextTag do not get saved for 'other' accounts ie accounts which are not set as current and do not appear in the Trade Orders window.
[2022-03-18 16:15:36] |
What ACSIL function are using to submit the order? And are you referring to submitting an order for a different account, different than the trade account the chart is set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-18 16:36:22] |
What ACSIL function are using to submit the order? sc.BuyOrder(..) / sc.SellOrder() And are you referring to submitting an order for a different account, different than the trade account the chart is set to? Correct |
[2022-03-26 06:43:00] |
Sierra Chart Engineering, Any update??
