Date/Time: Mon, 10 Mar 2025 07:03:05 +0000
High and low difference on visible chart
View Count: 563
[2022-03-18 15:21:53] |
Tonkadad - Posts: 235 |
Is there a way to get the difference between the high and the low of the visible bars on chart? Ideally in a text box. |
[2022-03-18 17:55:55] |
John - SC Support - Posts: 38516 |
The only way we can think to do this would be to use the Volume by Price and set the Volume Graph Period Type to Visible Bars, then set the Value Area Percentage to 100. You can then reference the Value Area High and Value Area Low subgraphs from the VbP to get what you want. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
