Date/Time: Mon, 10 Mar 2025 07:21:45 +0000
DIA RT ARCA data
View Count: 547
[2022-03-18 13:24:14]
User532947 - Posts: 13
Hi I have current Denali data subscriptions. I understand from other posts here that ARCA data is part of Denali.
I am only receiving DELAYED DIA (ETF) data for 7 days back and need realtime. I use the API to IB. Do I need to add an ARCA subscription under Denali for ETF/STock data? Or is this a technical matter of the IB API working with Denali?
[2022-03-18 17:33:01]
John - SC Support - Posts: 38516
We see that you have activated the NASDAQ TotalView exchange for your account, which will give you the real-time data you need.
If you are still having an issue, then make sure that the symbol is entered as DIA-NQTV in order to get the TotalView data.
