Date/Time: Mon, 10 Mar 2025 07:05:30 +0000
Error loading intraday data
View Count: 530
[2022-03-18 11:06:54] |
User794675 - Posts: 1 |
Hello SierraChart team, I have a problem loading intraday data, current version. The intraday data is only loaded and displayed from the start of a Chartbook, everything before the start of the Chartbook is displayed as zero. I also have an older version of SierraChart and use the same Datafeed, everything is loaded and displayed correctly. I've made settings and tried various changes, cleared and reloaded data, it doesn't work. Can you give me advice? Thanks... |
[2022-03-18 15:36:53] |
Refer to the version notes here for version 2351 regarding this: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2351 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
