Date/Time: Mon, 10 Mar 2025 07:22:01 +0000
Assistance reactivating (download not working)
View Count: 501
[2022-03-17 23:01:15] |
peaceland - Posts: 95 |
Hi, been a few moons. Tried to activate and buy data, but was directed to the software. Software says: need to update to latest version. Tried to download. Fails. Please advise. Thank you. Peace |
[2022-03-18 05:15:26] |
George Xia - Posts: 9 |
You can try using the zip installer: Software Download: Sierra Chart Zip Installer |
[2022-03-18 15:31:22] |
Let us know if you need more help.
