Date/Time: Mon, 10 Mar 2025 06:49:47 +0000
How can i save my chart, T&S, DOM, Quoteboard All in 1 chartbook or template?
View Count: 525
[2022-03-17 21:39:25] |
Sivle - Posts: 67 |
ok, so i have my chart up, and my custom DOM and my time and sales and also my quoteboard with my symbols and now i want to save them all in 1 chartbook. So when i open sierra chart i can easily open everything up quicklt by opening my chartbook. basically i want to save everything in 1 template so that i can open everything up faster in the future. Can i do this? how do i do this? i appreciate every comment on this. Because its very painful to open everything manually every time. |
[2022-03-17 22:20:11] |
John - SC Support - Posts: 38516 |
Just save the Chartbook while you have everything open. And do not close any windows before exiting from Sierra Chart (just to ensure you do not overwrite when exiting if you select Yes to saving again). Then when you open that Chartbook again, everything will be as it was. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-18 18:20:29] |
UFODetective - Posts: 10 |
Hello, I am having this same problem on this newer version of Sierra. Specifically my QuoteBoard... Its set fields stay in tact however, I have manually created the window/its boarder a specific size. I set it to a certain window size, save the QuoteBoard, then click 'save all' in the main window to make sure, exit, and when I turn the platform back on the size of the quoteboard changes back to some sort of default. I really don't like that this is now apart of my regular morning routine to fix the window size on multiple chartbooks I have open. Despite it being a quick change, it is starting to get irritating. How can it remain the way I set it up to? Attached 1 screenshot of my full size window to what I have setup on all my chartbooks and the 2nd screenshot to what it collapses to upon re-opening Sierra. |
[2022-03-19 09:27:13] |
Sierra_Chart Engineering - Posts: 18724 |
Nothing has changed with this functionality for years with saving and restoring a Quote Board window. This does look to us like an operating system issue. We have made one small change that will be out in the next release which might help. If not, this is not anything we can solve from our side. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-22 17:35:42] |
Thanks, you could be right. Only, I've been using the same OS and PC on the previous Sierra versions. Now, even when I minimize Sierra and then maximize again, the quoteboard reverts to its mini version. It's strange, only on some of my chartbooks does this occur. Will try to diagnose it on my end some more. Thanks anyway |
