Date/Time: Mon, 10 Mar 2025 17:09:34 +0000
ES 3 minute chart
View Count: 617
[2022-03-17 19:42:08]
Dennis B. - Posts: 286
Before when I had a 5 minute esm chart and I typed in 3m, I got a 3 minute esm chart, great. Now if I do that I get "Symbol settings not found for current service" Does SC not support a 3 minute chart any longer ?
[2022-03-17 20:06:28]
Somethings out of whack,all worked fine this AM.
[2022-03-17 20:49:52]
John - SC Support - Posts: 38541
It's possible that what you had typed in was thought to be a symbol rather than just the chart timeframe change. Refer to the following regarding changing the symbol from the keyboard and the 3 sections after it which give you information on how to turn this off:
Changing the Symbol of a Chart: Quickly Changing the Symbol of a Chart to a Symbol for which a Data File Exists
[2022-03-18 12:16:36]
Didn't do a thing, but everything's working like normal this AM. Blame it on Comcast.
[2022-04-06 20:08:32]
Same problem as before, I went to general settings but could not find ( Support symbol entry from chart window) Could this be a server issue ? Will try in the am tomorrow.
[2022-04-06 20:43:14]
In the new General Settings, the option to turn on/off the Symbol entry is in Global Settings >> General Settings >> Chart >> Support Symbol Entry from Chart (it's under the Symbol section under the Chart tab).
[2022-04-07 12:26:34]
Same as before, booted up this am and did't do a thing. Everything is working great no problems,this as to be a server issue ...
