Date/Time: Mon, 10 Mar 2025 10:56:10 +0000
prop firm tryout with real account
View Count: 1735
[2022-03-17 17:24:21]
User334419 - Posts: 17
I would like to have a test with a prop firm using sierra chart. The test is in sim mode, I would like to continue trading with my personal trade account and connect the prop firm's account to my account to do copy trading Is this possible?
[2022-03-17 17:51:28]
John - SC Support - Posts: 38516
We do not have a way to copy trades between different brokerages. The ability we have can only be done when you have multiple accounts within the same brokerage such that the multiple accounts will show up within Sierra Chart with the single login to your trading accounts. Refer to the information here:
Order Allocation to Trade Accounts
Our recommendation is to install a second Sierra Chart that you use with the Prop firm. As long as this is on the same computer, you will be able to use the Denali Exchange Data Feed to both installations for no extra fees. Refer to the information here:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
[2022-03-21 14:11:09]
hi
is it possible to have a team viewer to install it ? (a second sierra chart )
[2022-03-22 00:48:44]
This is really very easy. The instructions are here:
Just simply install Sierra Chart to another folder on your computer system. Very straightforward.
[2022-03-24 15:50:49]
I would really like to have a teamviewer with you and is ready to pay the costs because I have several questions to ask you and it will be easier by teamviewer
[2022-03-24 17:24:14]
This is not something we have the time to do. We recommend contacting Diana Pena as someone that can help you. You can contact her here:
https://bio.link/dianapena
