Date/Time: Mon, 10 Mar 2025 07:04:10 +0000
crosshair always on
View Count: 1824
[2022-03-17 17:13:54]
maliik3103 - Posts: 48
how can i make the crosshair always visible, even when i am currently using the hand
[2022-03-17 17:40:20]
John - SC Support - Posts: 38516
You will want to set the options for Global Settings >> Tool Settings >> Chart Values >> Always On when Chart Values Tool Selected to Yes and Global Settings >> Tool Settings >> Chart Values >> Action When Other Tools Selected to Always On when Using Other Tools.
Refer to the information at the following link and the one after it:
Chart Drawing Tools: Always On When Chart Values Tool Selected (Tool Settings >> Chart Values >> Chart Values)
[2022-03-17 19:20:50]
https://prnt.sc/YyDlEAtrDpsd , its still not working
[2022-03-17 20:36:43]
What "tool" do you have selected? The one situation for which the crosshairs will NOT show up is when the tool is set to Pointer.
