Date/Time: Mon, 10 Mar 2025 02:26:04 +0000
Tenko data
View Count: 446
[2022-03-17 17:07:54]
User546493 - Posts: 1
My trading account is with IB. How can I use your server side order system and data feed of yours?
[2022-03-17 17:24:05]
John - SC Support - Posts: 38516
You can not use our Order Routing service with IB. They have their own connectivity to the exchanges. If you are interested in using our Teton Order Routing, then refer to the information at the following link, specifically note the list of brokers at Step #2 of the Setup Instructions:
If you want to use our data with Interactive Brokers, then this is not a problem. Just go through the appropriate Setup Instructions for the data you need as found on our Denali Exchange Data Feed page:
Then go through the information at the following link to ensure that your system it setup properly to get our data and trade with IB:
Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services
