Date/Time: Thu, 24 Sep 2026 12:33:07 +0000
Entering study data into Sierra file
View Count: 677
| [2022-03-17 16:42:57] |
| User57584 - Posts: 30 |
Hello, One of the Studies I am using is the "Horizontal Lines". I have in there numerous lines that I use to fill manually to create zones. Is there a possibility to directly enter those data (from an Excel sheet for instance) into the Sierra file present into my C disk ? Thank you very much in advance. Best regards, Jean-Marie Boulay |
| [2022-03-17 16:54:43] |
| John - SC Support - Posts: 47994 |
You would have to create a custom study to do this. Refer to the information here: Advanced Custom Study Interface and Language (ACSIL) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
