Date/Time: Mon, 10 Mar 2025 16:04:23 +0000
cant update
View Count: 515
[2022-03-17 10:50:52]
maliik3103 - Posts: 48
i cant update to a new version, i have sent a log
[2022-03-17 14:15:22]
John - SC Support - Posts: 38529
This is the important line from the log:
Failed to create folder: C:\Users\HP\Desktop\sc - Kopie\DownloadedInstallationFiles\ACS_Source\. Windows error code 5: Zugriff verweigert
Refer to the information here:
Software Download: Resolving 'Access is Denied' Errors
If you continue to have issues, you can try the Zip installer, which can be found here:
Software Download: Sierra Chart Zip Installer
[2022-04-02 20:51:37]
We really do not recommend you are installing it to the location you are. This is what is causing the problem.
Use the standard default location which is C:\SierraChart.
