Date/Time: Mon, 10 Mar 2025 01:46:18 +0000
add 2 footprint (numbers bar) in the same chart
View Count: 497
[2022-03-17 06:04:12] |
TradingMarketProfile - Posts: 120 |
hello, I would like to add 2 different footprint in one chart, i tried different ways but nothing so for exemple ES and YM numbers bar or 2 ES but one with volumes filter thanks |
[2022-03-17 14:08:49] |
John - SC Support - Posts: 38516 |
You can not overlay a Numbers Bars to a different chart, so you can not do what you are looking for. Just in case you are interested, you can do this with the Numbers Bars Calculated Values studies. Refer to the information here: Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
