Date/Time: Mon, 10 Mar 2025 02:22:23 +0000
package change
View Count: 492
[2022-03-16 22:47:58] |
maliik3103 - Posts: 48 |
is it possible to change my package to the one with denali data feed, becaue i cant connect to rithmic with my current package service, and both packages have the same price
[2022-03-17 01:27:51] |
You can actually connect to Rithmic on service package 5, but we have now changed it to 11. However, if you still cannot connect, we would need to see the Message Log to know why. Instructions: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Connect to the data feed: Select "File >> Disconnect" Select "File >> Connect to Data Feed" After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-03-17 09:09:48] |
so is it possible to normally trade with rithmic if ure on package 5 and dont have denali feed ?
[2022-03-17 10:42:49] |
The answer is no. You need to have Service Package 10 or higher, and pay the required exchange fee. Otherwise, you will have issues with historical data.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-17 13:07:18
