Date/Time: Mon, 10 Mar 2025 02:11:02 +0000
'Chart setting' looks different than before
View Count: 1011
[2022-03-16 17:14:26]
locl - Posts: 1
I've reinstalled Sierra Chart on another PC and the 'chart setting' menu looks different.
Instead of having 'main settings' 'advanced settings' 'advanced settings2' 'advanced settings3' etc, and a grey background, when I open my chart settings '[Symbol]' '[Data limiting]' ['Bar period]' etc comes up with a black background (which has the similar look as when opening 'global settings')
There's no problem in changing the chart setting with it, but it's inconvenient compared to what I used before. Is there a way to change it to the 'grey background' default layout?
Date Time Of Last Edit: 2022-03-16 18:12:01
[2022-03-16 18:18:40]
John - SC Support - Posts: 38516
This is the new windows now applied to the Chart Settings. It will take a bit of time, but you will eventually learn to use this as easily and probably quicker, than before.
There is not a way to convert back to the previous windows. There are some settings that can change how the window looks an acts. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#UseSingleClickToEditItemInSettingsWindow
and there are new Graphics Settings for the window for which we need to update the documentation.
