Date/Time: Mon, 10 Mar 2025 03:05:11 +0000
Encountered unknown field. Teton Order Routing
View Count: 443
[2022-03-16 16:24:17] |
ertrader - Posts: 682 |
Hi Support, I get the following message when connecting. I'm using Stage 5/Advantage. Trading is working fine so not sure if this is anything important. Reading Internal Order ID file. | 2022-03-16 12:13:39.483 Reading Trade Orders file. | 2022-03-16 12:13:39.530 Reading Trade Positions file. | 2022-03-16 12:13:39.530 Reading Trade Account Data files. | 2022-03-16 12:13:39.531 Encountered unknown field code when reading account balance data. | 2022-03-16 12:13:39.531 |
[2022-03-16 16:31:47] |
No this is nothing to be concerned about but next time you restart Sierra Chart we would not expect you would see it and we do not know why you have received this unknown field message.
