Date/Time: Mon, 10 Mar 2025 02:31:38 +0000
DOM Speed Difference
View Count: 968
[2022-03-16 16:08:30]
knarf01 - Posts: 48
Good morning,
I got a Delta number bars study from a friend and the DOM updates so fast, which is great. My DOM's on my own charts do not update so fast. Assuming nothing changed under Global Settings what else could be the determining factor for this? I would like to see this speed on my other DOMs as well.
Thank you!
[2022-03-16 16:30:25]
John - SC Support - Posts: 38516
The item that controls this is the Chart Update Interval. There is a per chart setting and a Global Setting. Refer to the information here:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
[2022-03-17 14:25:19]
knarf01 - Posts: 48
Could it be something different? I checked the Chart DOM settings and Global Settings, both of them are the same. This one chart has very fast updates on the DOM (just want to clarify, its a DOM thing).
[2022-03-17 14:27:40]
The global Chart Update Interval should be increased, to 500 ms to 1000 ms. Where you need faster updates only use the chart specific one and reduce it where necessary. Also refer to:
Chart Trading and the Chart DOM: Improving Performance Of Chart / Trade DOM
