Date/Time: Mon, 10 Mar 2025 07:14:58 +0000
Issues with Dom and Chart trading mode
View Count: 709
[2022-03-16 15:12:08] |
User776992 - Posts: 8 |
Quick question, I can't seem to figure out how to manually put a sell limit or buy limit order that's above the price on the Sierra dom or chart when I have chart trading turned on or just in trading off of the dom. So let's say I buy 1 micro contract at the current price of 13500 of the NQ. I then want to put a sell stop limit at 13600, meaning that the sell stop limit will close out the position. It won't let me if I right-click on the dom or the chart and it has an error that says it's rejected due to a sell stop must be below the current price. That doesn't seem right to me as I'm live trading because I can do it when I'm sim trading any help would be greatly appreciated. I also figured out how to do it with brackets, but I want to be able to do it manually. Thank you. |
[2022-03-17 22:38:31] |
Understand these rules about Stop orders: Order Types: Stop And make sure you understand the order type being used on the Chart/Trade DOM: Global Trade Settings Windows: Chart DOM Settings Depending upon the particular action you are performing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-03-17 22:39:05
