Date/Time: Mon, 10 Mar 2025 03:25:47 +0000
Is there anyway to get this type of subgraph for a TICK chart?
View Count: 473
[2022-03-16 14:48:11]
User544395 - Posts: 15
Hello all, I was wondering if it would be possible to get the type of subgraph on the Commodity channel index, except change it to market internal TICK-SP data. Basically the TICK-SP market stat in the form of the photo below for reference.
Date Time Of Last Edit: 2022-03-16 14:50:09
imageCCI.png / V - Attached On 2022-03-16 14:47:50 UTC - Size: 6.81 KB - 147 views
[2022-03-16 15:35:42]
John - SC Support - Posts: 38516
You would have to use the Study Subgraph Reference and determine which part of the Tick-SP bar you want to use (Open, High, Low, Close). Then set the Draw Style for the subgraph in that study to Bar. Refer to the following:
Chart Studies: Bar (ACSIL: DRAWSTYLE_BAR)
