Date/Time: Mon, 10 Mar 2025 03:07:05 +0000
connection limit exceeded after change to Teton Order Routing
View Count: 498
[2022-03-16 13:51:46]
User268846 - Posts: 17
Hello SC,
after the change to Teton we experience disconnections on our second Sierra Chart instance:
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-03-16 09:29:14.657
it seems that there is a limit of 1 connection only. This is a problem since we have a production instance running in the datacenter and one development instance locally and need connection for both.
How can it be fixed?
thanks
[2022-03-16 13:57:00]
Refer to:
Denali Exchange Data Feed: Connections
